Soldering stationsq
Reply
Old 12-16-2017, 12:59 PM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Soldering stationsq
Hi,
I have always wanted a good soldering station. I just talked the wife into getting me one of xmass.
anyone got a suggestion on a good one, I would like to keep it under $150.
thanks
stick
Stick 40 is offline
Old 12-16-2017, 09:27 PM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You do realize that's an open ended question, don't you?
Solder stations can be your best friend or your worst nightmare, been there and found that out.
My experience is that you can't do wrong with Weller soldering tools. Here's one that may fit the bill for you:
https://www.micromark.com/Electronic-Soldering-Station
I would recommend getting some of the available various sized extra soldering tips to increase the station's versatility as well.
One thing to be aware of is that this is not a high dollar station but, unless you do a lot of heavy soldering, you probably don't really need to spend that kind of cash to buy one either
Hydro Junkie is online now
Old 12-17-2017, 07:23 AM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Solder Station with LED Display, ZD-929C | MPJA.COM
Steve Percifield is offline
Old 12-17-2017, 08:13 AM
murcielago
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was big into bramd na,e soldering stations like weller because thats what was used in comercial environments. I went through two of them before realizing that good old China made some damn good ones at a fraction of the cost. Wellers were well over 100 clams wereas you can pick up a No Name station for less than 30, and so far outlived the weller. One good habit with a soldering station is too always have solder on the tip. So, if you are working on something, before you put the wand back on the stand, clean the tip on the sponge or brillo, melt some solder on the tip, and then let it rest on the stand. This will prolong the life of the tip and inner somponents. Look on ebay and save some money.
murcielago is offline
Old 12-17-2017, 05:28 PM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info, I will tell her.
I am redoing my hobby area in the basement and this will be a new item
sticks
Stick 40 is offline
Old 12-20-2017, 07:24 AM
Rotten40851
Rotten40851's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get yourself this one, I have it, it is awesome. Get extra tips and the cleaning station as well
https://www.towerhobbies.com/cgi-bin...?&I=LXATBK&P=3
https://www.towerhobbies.com/cgi-bin...?&I=LXDHTB&P=M
Rotten40851 is offline
Old 12-21-2017, 06:02 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
I´m still using my 45 year old 50W Weller soldering station (with three different tips). It handles 5mm piano vire with ease using the widest tip.
Name:	Weller lödkolv 001.jpg
ID:	2248218   Click image for larger version
Name:	Weller lödkolv 002.jpg
jaka is offline
Old 12-21-2017, 07:23 AM
OldScaleGuy
OldScaleGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stick, it depends a lot on what you plan to solder, the soldering stations recommended are in the 40-60 watt range. If you are doing electronics these are fine. If you plan to solder large landing gear, then you need something with 150-200 watts to do a really good job of it.
OldScaleGuy is offline
