Nelson Hobby Paints?
Reply
Old 01-01-2018, 03:34 PM
Pork Chop
Pork Chop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Nelson Hobby Paints?
Hey guys does anyone know if Nelson Hobby still around? I was looking for their website to buy some paint and can't find them
Pork Chop is offline
Old 01-01-2018, 10:56 PM
RDJeff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can buy the paint direct from System 3, but only in the standard colors.
RDJeff is offline
Old 01-02-2018, 08:01 AM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to Home Depot and buy Behr latex paint in the sample cans. They will mix any color you want. I think the sample cans are under $5 each. Both are latex paint. The Behr paint is excellent. A sample can will paint several planes
Steve Percifield is offline
Old 01-02-2018, 08:40 AM
Pork Chop
Pork Chop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RDJeff, thanks for the heads up on the paint. Steve, I'm assuming you spray the Behr, do you thin it?
Old 01-02-2018, 08:54 AM
Steve Percifield
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually I brush most of it. I build primarily WW1 models and the brushing works better. Buy a quality Latex brush, synthetic bristles. Do not use a foam brush. I keep the brush wet, by dipping it in water, a quick tap onto a paper towel , then into the paint. I do this every brush load. I like 1" and on larger areas 2" brushes. Do not let them dry. Either immediately clean them or put them in a cup of water.
Now having said that, I am building a 1/3 scale se5a that has a lot of metal on the front of the fuse. I sprayed that. I thinned the paint about 25-30% with water. I experimented on the amount before spraying the plane. It worked very well.
steve
Old 01-02-2018, 09:22 AM
Pork Chop
Pork Chop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great information Steve much appreciated and good luck on the big se5a if your doing a build thread I'd like to follow along
Old 01-02-2018, 12:52 PM
Steve Percifield
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't do build threads , but here are a couple of pictures
ID:	2249726Click image for larger version
ID:	2249727Click image for larger version
ID:	2249728Click image for larger version
Old 01-02-2018, 01:54 PM
RDJeff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The System 3 paint is actually a water based polyurethane, not a latex. It is boat paint, and is water proof, and mildly fuel proof. If you add their cross-linker to it, it then becomes very fuel proof. It cleans up with water, and you can use water to thin it also. There's a good thread about using it on the RCG site if you're interested. I've used it on several planes now, with good results.
QUOTE=Steve Percifield;12394804]Go to Home Depot and buy Behr latex paint in the sample cans. They will mix any color you want. I think the sample cans are under $5 each. Both are latex paint. The Behr paint is excellent. A sample can will paint several planes[/QUOTE]
RDJeff is offline
Old 01-02-2018, 04:33 PM
Pork Chop
Pork Chop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve, man she's beautiful!
RDJeff, I just found a couple of threads on RCG thanks for the tip. I found a building thread here on RCU where a first time painter brushed on the System 3 with great results which is why I was interested in the first place. Thanks again guys for all the input I really appreciate it.
Old 01-02-2018, 07:40 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Home - WarbirdColors also uses the Systems Three paint but mixed to match scale planes.
jester_s1 is offline
Old 01-02-2018, 08:03 PM
RDJeff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jester, I had no idea someone else was mixing the System 3 stuff!
RDJeff is offline
Old 01-03-2018, 12:53 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Systems 3 Satin clear over latex works great for warbirds IMO,, and as stated if you use the crosslinker it is very fuel proof
Examples with Satin Clear
ID:	2249822   Click image for larger version
ID:	2249823   Click image for larger version
scale only 4 me is offline
Old 01-03-2018, 08:51 PM
Ralph White
Ralph White's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can Systems 3 Satin clear with crosslinker be used over Rust-oleum Painter's Touch 2X ? Also what size jar would be needed to cover a 1/5 scale P-51 Mustang?
Thank you
Ralph White is online now
Old 01-04-2018, 04:18 AM
scale only 4 me
My Feedback: (158)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Being water based I'd think it could go over anything, on the Zero, I used it over the Rustolem Flat Black,,soaked right in no problem just like with the latex.
I'd think One small sample size jar should be enough to seal a plane that size,, but @ $5 each buy 2,, you'll use it later,,
Good luck
Old 01-04-2018, 04:46 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two things about that- this stuff does not stick to glossy surfaces, so you'd need to paint with Rustoleum flat or either color sand the gloss off it with 320 grit. Second, solvent based paint takes a pretty long time to fully outgas. If it still smells like paint, it's not finished. If you put the WBPU over it before it's done, it could lift and peel after a while.
So yes, this paint will work fine as a protective clear coat over fully cured non-glossy Rustoleum. But you'd make life easier for yourself by either painting with Systems 3 color to begin with or using it to topcoat flat latex which only needs about two weeks to fully harden, maybe a bit longer in the winter.
Old 01-04-2018, 05:17 AM
scale only 4 me
My Feedback: (158)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree Jester,, thanks for mentioning that, I forgot about that, First plane I used it I sprayed it over some satin finish grey from Lowes and it did want to fish eye a little,, I just wiped it down with denatured alcohol to take the shine off and it went on and stuck fine,, Over the Flat is the way to go,, this was my learning experience Will it be good for another 15 years?
good luck
Old 01-04-2018, 07:05 AM
Ralph White
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the replies. Since I already have some Rust-oleum gloss on the model I think I will stick with Klasscote clear on this one. I will be trying the System Three on my next model.
Old 01-04-2018, 09:21 PM
Pork Chop
Pork Chop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone for weighing in with all your experience.
