Fueling options on Great Planes Skybolt 60
Reply
Old 01-05-2018, 05:27 AM
Skeezix4me
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fueling options on Great Planes Skybolt 60
Getting back into fixed wing glow after a 18 year hiatus, and am building an old Great Planes Super Skybolt 60 kit. Iím running a Hayes 13oz tank, and either an OS .91 Surpass II, or OS FS-1.10a. I also have a Slimline Pitts in cowl muffler for the setup. My idea is to keep this a clean setup all around
Reaching out for opinions and help on setting up fueling on my model. The Hayes 13oz tank doesnít allow for a true 3 line setup, and thus Iíve been looking at other fueling options:
-DuBro Kwik Fill: heard too many bad things about leaking valves: etc: https://www.dubro.com/products/kwik-fill-fueling-valve
-DuBro E/Z filler: not sure about this one Ė but doesnítí seem popular: https://www.dubro.com/products/e-z-fill-fueling-valve
-Fuel Dot: Seems popular but my tank isnít set up for a dedicated Ď3rd lineí: https://www.dubro.com/products/fill-it-fuel-system
-Slimline Excel Fueler: The best option Iíve found so far but donít see many folks using them: Excel Fueler System - Slimline Excel Products
-Robart Super Fueler: https://robart.com/collections/fuel-...s/super-fueler
-ĎTí-connector: I ran across this thread, and it looks simple, effective, and cheap, I just worry about forcing fuel into the carb: https://www.flyinggiants.com/forums/...ad.php?t=79914
Any other ideas or wisdom would be much appreciated as I am at a stopping point with the build until I work out the fueling issue. and know where to drill the firewall
Thanks to all!
Skeezix4me is offline
Old 01-05-2018, 09:14 AM
jrf
My Feedback: (551)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are right. Anything with a valve will eventually leak. The straight through T or fuel dot setup works fine, but you have to pull the idle all the way down to shut off fuel to the carb. I suggest that you buy a 3 line tank.
jrf is offline
Old 01-05-2018, 09:17 AM
52larry52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put the Hayes fuel tank back on the shelf and buy one that will use a 3 line system (fuel tanks don't cost much). Or Use the Dubro fueling valve knowing that after a couple years of use that replacement of the valve may be needed if it acts up. Also, they do sell a repair kit (new O rings) for their fueling valves when maintenance is needed. All low cost options.
52larry52 is offline
Old 01-05-2018, 10:03 AM
Skeezix4me
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the replies. Several things I want to ask:
1)Who make a good 13oz/14oz 3-line tank?
2)Did you see the Slimline filler I listed above? It doesn't have moving parts to fail, and will work with the two-line system.
3)As I've been reading more and more this morning, I'm leaning towards the 2-line set up with my existing tank, and just using a 'T' fitting with a fuel DOT between the line from the tank-to-carb. Yes, I understand I'll have to close the throttle all the way to fill. Are there any other drawbacks from this setup I need to be aware of?
Nothing here is perfect, but I'm trying to weigh everything.
Old 01-05-2018, 10:17 AM
RCFlyerDan
My Feedback: (51)
RCFlyerDan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IMHO......The "T" with a fuel dot is the cheapest and most reliable. Any of the DuBro valves are a "gotcha once" valve. . You buy them once because they are a great idea, but get any sand or other dirt onto the fuel tip and insert it into fill, you now have an irritant to the O-ring. Thus an air leak and a dead stick. Can even happen on the first fueling too. The Slimline or Robart are the best out of all of them. But, stick with the "T" or 3-line tank.
RCFlyerDan is online now
Old 01-05-2018, 10:56 AM
jameighan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
I replace the "O" rings every 5 years or so. I purchase them at my local ACE Hardware store.
FYI,
Jim Meighan
jameighan is online now
Old 01-05-2018, 11:07 AM
Skeezix4me
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you all for the replies.
Regarding the Slimline Excel filler, does anyone know of a similar type product that is available? It doesn't have any moving parts to fail or get stuck (like the DuBro), and works perfectly with a two-line set up. I'm interested to see if there are any other fillers like that one that are available.
-Tim In Texas
Old 01-05-2018, 01:25 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My 60 size Ugly Stick has a Kraft three line 13 oz. rectangular tank, although I use it as a two line. I fill through the line to the carburetor. I have to ask which Kraft tank do you have that doesn't have all three lines?
GREG DOE is offline
Old 01-05-2018, 02:06 PM
Skeezix4me
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my Hayes tank has 3 ports as they all do, however the third port/nipple is the same as the pressure nipple - there isnít a provision for a second line with clunk for fueling/defueling.
Old 01-05-2018, 04:55 PM
jrf
My Feedback: (551)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nothing is fool proof. The T setup requires that you close both the throttle AND the idle trim to prevent leaks through the carb. Then you have to remember to raise the trim again or the engine won't start. The Slimline and Robart have the same problem with foreign material fouling the O-rings as the Dubro. Buy a three line tank.
jrf is offline
Old 01-05-2018, 05:24 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I learn new stuff every day. I've never heard of a two clunk line tank? I fuel and de-fuel through the engine supply line, and over-flow out the pressure line. If I have an airplane where the carburetor supply line isn't accessible, I set up a three line system where I fuel, and over flow from the two vent ports, and then plug off one of them. To de-fuel I hold the airplane upside down, nose low, and suck. Kraft tanks have served us well for almost 50 years. Maybe you need a Sullivan tank with two clunk lines?
GREG DOE is offline
Old 01-14-2018, 01:25 PM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Best tank is a Tettra "Bubble-less" tank ! No rubber stopper that can leak and you can use it with or whitout the inner silicon rubber balloon.
Next best is using a ordinary Sullivan, or Du-Bro (or what ever) tank , but set up with two clunks,one for pressure and the other for fuel to the carb, third line goes up at the top and serves as overflow. This tank system gives more even pressure and thus better fuel delivery than an ordinary 2-line system and has been used by control line fliers since the fifties (and by me and other in R/C for more than three decades) .
Pictured below is how I mounted the tank, fuel lines and fuel needle inside the cowl of my GE BEE R-2 powered by a MVVS 15cc engine.
The two lines going down behind the engine (Yellow and green) is for fueling and overflow. They are pluged during flight. Tank is a Tettra Bubbleless!
ID:	2251049   Click image for larger version
ID:	2251050   Click image for larger version
Name:	tn_GEE BEE R1Motor och tank snett frŚn všnster.JPG
ID:	2251051   Click image for larger version
jaka is offline
