Slimline muffler
Slimline muffler
Has anyone heard that slimline mufflers can cause an engine to dead stick? It is supposed to be the muffler doesn't have enough back pressure to cause the fuel to have enough pressure and the plane will dead stick. The solution is to plug one of the muffler outlets to gain fuel line pressure. I know this is a question for the old time fliers but some of you must have an opinion. Let us know!
My Feedback: (20)
You are right about the pressure causing the engine to quit lean. I don't remember the brand, but I had to plug one outlet of a muffler on a Super Tigre .90. I have measured the pressure on a three-line tank by putting a long piece of tubing on the fill line and running it up a yardstick to make a manometer. Leave the tubing open at the top. All of the engines I have checked made a column of glow fuel about 16" high at full throttle. I used this info to make my own mufflers.
Chuck
Chuck
That's one reason I don't use slimline mufflers. That, and IMHO they don't muffle very much. I have also heard to NOT plug a tube, as oil/unburnt fuel/slime will accumulate in the blocked tube. I have tried 'crimping' the end of the tubes to get more back pressure, but it didn't work very well.
A lot of the aftermarket mufflers like Slimline and Jtec are really more like exhaust diverters. People use them to get the exhaust to a more scale like or convenient position. R8893 is correct about needing some back pressure for the fuel system. A lot of the issue depends on the specific muffler that you are using. Some of these mufflers are designed to mate to a specific engine and probably work well in that application. Other mufflers, especially some of the older designs, are made to fit a range of engines. You may have ended up with a muffler that has a lot more exhaust area than the stock muffler for your engine, even to the point of being an open exhaust. For example, you may have a pitts style muffler where both of the tubes have an exhaust area that together are equal to much more than the original muffler. In that case plugging a tube or reducing area can make a difference. It's a balancing act. The best outcome is to end up with a muffler that has about the same flow and back pressure as the stock muffler. Pressure tap location also has an impact. The pressure in a muffler is not the same in all areas. If you look at a stock muffler you will see that the tap is usually located in the area of greatest volume inside the muffler. One muffler that I had, that was not much more than a cube with an angled exhaust tube coming out, worked best with the nipple placed so that the opening looked right down the engines exhaust port. I don't say this to be down on Slimline, JTec or other mfg.s When used effectively they do a great job of getting the exhaust where you want it. It's just that you may have to modify or tune to get the desired performance and reliability.
Your mileage may vary but that's my two cents worth.
