Screws vibrating out
Reply
Old 05-07-2018, 07:49 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Screws vibrating out
I have reatored an old Wildhare Sukhoi and flown it a few times. The canopy is held on by 4 screws that go through the fuselage into a blind nut in the canopy. I can't really tighten those screws as it would crush the balsa structure. Two vibrated loose and fell out last time I flew it. So does anyone have a solution? I can't Loctite them because I have to remove the canopy for assembly. Maybe Vibratite? Maybe a neoprene washer? Something else?
jester_s1 is offline
Old 05-07-2018, 08:15 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put clear tape over them.
GREG DOE is offline
Old 05-08-2018, 03:38 AM
OldScaleGuy
OldScaleGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you remove the blind nuts add some plywood reinforcement and reinstall the blind nuts? That would allow you to use washers and lock washers.
OldScaleGuy is offline
Old 05-08-2018, 04:13 AM
Top_Gunn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put a thin sliver of wood inside each blind nut, next to the screw. Something sort of soft, like maybe spruce. You could try balsa, maybe ...
Top_Gunn is offline
Old 05-08-2018, 06:45 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The solution to your problem.
RTL Fasteners - Hobbies, Radio Control, ( R/C or RC ), locknuts, metric screws, servo screws, socke: Rubber Backed Bonded Washers
BarracudaHockey is online now
Old 05-08-2018, 07:13 AM
A. J. Clark
A. J. Clark's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used Orings with success. Compress then some and they act like lock washers.
A. J. Clark is offline
Old 05-08-2018, 08:02 AM
Steve Collins
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nylon bolts are less prone to vibrating out.
Steve Collins is offline
Old 05-08-2018, 08:52 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I didn't even think of using nylon bolts. There is very little stress on these, so they would be plenty strong. I'll try that before going to the neoprene washers.
Old 05-08-2018, 09:38 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dude, get you a bunch of them, they have all sorts of uses. Screwing down cowls they don't hurt the fiberglass, vibration resistance they won't back out, all manner of uses. I get a box from McMaster Carr for doing all the stab bolts and such on my gassers.
Old 05-08-2018, 03:29 PM
DGrant
DGrant's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bonded washers are very good for these types of applications. A bonded washer is a steel/metal washer, with a rubber washer bonded to it which creates a cushion/bed. There's different types and sizes of course, but you get the idea. Essentially they might be like putting an o-ring behind a washer... but much better.
I use those quite a bit for canopies and cowlings, and anywhere vibration might be present... as well as areas that might be a bit softer.in one way or another.
McMaster Carr has a good supply of them... in different sizes that fit most every size screw on planes from small to giants.
DGrant is offline
Old 05-08-2018, 04:14 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thumbs up
Exactly....I had some on my Escapde MX cowl for a long time and not one of them ever came loose.
now my son uses them on his 170cc planes and has the same results!
Jerry
tailskid is offline
Old 05-08-2018, 08:32 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where the screw passes through the fuselage side, open up the hole just a little and glue in a nylon flanged bushing. Install through the outside with thin CA and trim flush to the inside with a razor blade.
speedracerntrixie is offline
Old 05-09-2018, 07:49 PM
Pylonracr
Pylonracr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another quick and easy solution is to cut a piece of fuel tube about 1/8" long and slide it up to the screw head. Compress it about half way and it will provide enough friction to keep the screw from vibrating out without cracking the canopy.
Scott
Pylonracr is offline
