O.S. 35AX Throttle Lever
Hello Everyone,
I need a O.S. 35AX throttle lever, after asking Tower, looking around on RCjapan.net, VVRC and O.S. parts listing I have discovered that there is not a separate throttle lever sold for this engine. I would need to be the carb which is around $80. Does anyone know if there is another O.S. engine that uses the same throttle lever as some are sold for certain engines. For example the .40 size O.S. has a throttle lever that is old separately. Please recommend if you know.
- AT
- AT
For $80 I would just buy a Magnum or ASP complete motor. I don't know what those guys are thinking. Well I guess I do know, just raid a motor for parts and charge the whole engine cost for one part. Nevertheless, I have used a servo arm for a throttle arm, and made arms from packing strap sheet metal. It would not be too much trouble to make up something. Even the fancy clamp on types have options.
