retract tank fill
Reply
Old 07-08-2018, 11:01 AM
WhiteRook
My Feedback: (38)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default retract tank fill
valve works , but cant get the tank to fill
WhiteRook is offline
Old 07-08-2018, 02:10 PM
DavidAgar
My Feedback: (107)
DavidAgar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a number of reasons. A leak, a hose kinked, one way check valve going the wrong way, not plumbed correctly, not hooked up to the control valve correctly. Your fill line should come off your fill valve, go to a T, split of the T to your tank and the third port of your T should go to your control valve. You mix up some dish soap and water and slide that solution over all your tubing and connections and if you have a leak, you will see bubbles. Good Luck, Dave
DavidAgar is offline
Old 07-08-2018, 02:36 PM
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chad Veich is offline
