Power requirements for a small Tiger Moth
Reply
Old 10-19-2018, 07:49 AM
378's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Power requirements for a small Tiger Moth
I found a deal for a pretty snazzy lookin' 980mm span Tiger Moth kit on Banggood, balsa and ply construction, that I'm thinking about picking up and building. Given it's made of balsa-and-ply and that I have a strict 'if it's big enough for ICE it gets ICE' policy regarding my aircraft models, I'm planning on going nitro with it.
I'm thinking of using a throttleable Cox 0.049 from coxengines.ca for it. Is that gonna be enough power? Or should I step up a bit and get an OS 15LA for it? I don't want so much power that I could 3D with it or set airspeed records, but I want enough power that 1/2 to 3/4 throttle is a lovely cruise speed while leaving enough in reserve for the occasional loop and/or aborting a dud landing. Also want to be able to take off from the ground on its own rather than relying on handlaunches.
378 is offline
Old 10-19-2018, 12:12 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you are on track with the 25 LA. Bipes tend to require a bit more power then monoplanes. I have a 70 bipe that flies really well with 70cc of engine.
speedracerntrixie is offline
Old 10-27-2018, 09:00 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The banggood page says that plane is meant to fly on a 2212-2216 motor. Himax says their 2212 is the equivalent for a .040 glow engine. So the Cox may work well. You might check into the weight of the bigger engines to see what kind of factor that will be.
jester_s1 is offline
Old 10-27-2018, 06:57 PM
j.duncker
j.duncker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It weighs around 20 to 25 oz so a Cox o49 will not fly it.
An OS 15 LA on a 8 x 3 should do the job.
j.duncker is offline
Old 10-27-2018, 07:34 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A very long time ago I built a Pitts Special using a couple Ace foam wings. Span was about 40" and I powered it with a K&B 3.5cc ( .21 ) and ran a 9x4 Rev Up prop. Weight was around 2.5 lbs. Pretty much had just the right amount of power. Quite the handful though, no dual rates or expo back then.
Old 10-27-2018, 07:37 PM
Pylonracr
Pylonracr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or if your runway sits at 5000' like mine you might want a touch more power.....
there is always the throttle
Scott
Pylonracr is offline
