Long and Short Glow Plugs in Webra 120
Reply
Old 12-24-2018, 08:24 AM
thailazer
thailazer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Long and Short Glow Plugs in Webra 120
Getting ready to run a Webra 120 and I noticed the glow plug is a long version. Is there any down side to using a short glow plug in this engine?
thailazer is offline
Old 12-24-2018, 09:37 AM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most large displacement glow engines were designed for a long plugs; from approximately .40's and up.You can run it on a short plug, but there might be a slight loss in performance. Because there isn't as much thread contact, be carefully not to strip the head. Also pressures are higher in larger engines, so long plugs are less likely to "blow out", although unlikely if the threads have never been abused. Try to stick with long plugs if you can, because that is what the engine was designed for, but in a pinch it shouldn't hurt to run a short. I wouldn't hesitate to do it in a pinch.
GREG DOE is offline
Old 12-24-2018, 09:51 AM
thailazer
thailazer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Greg... Good point about the extra threads helping the plug forces. I made a donation to the Strega P-51 team at the Reno Air Races years back and they gave me a spark plug from one of their qualifying runs. That thing had an incredibly long threaded base to handle the compression.
Just ran the engine with the original long plug on my Hangar 9 C-182. The Webra is an impressive motor with an incredibly low idle.
Old 12-24-2018, 12:26 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 120 is a fantastic engine. I ran mine with an Enya 3 plug and 10% nitro with 16% oil. They really like the APC 16x8.
speedracerntrixie is offline
Old 12-24-2018, 12:43 PM
thailazer
thailazer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I am very impressed so far! Fantastic idle and tons of thrust on a 15-7 3 blade. I notice that the compression when cold is quite low, but hot, it is higher. Is that a characteristic of the Dykes ring? No issue on power though.
