Just scored big at the LHS. What the hell did I buy?!
Picked this thing up from my LHS, TxR, $40. Siezed OS 40FP on the nose. Got it home and within 2 hours I had the engine running pretty much flawlessly at anything north of 1/4 throttle. Need to run it some more, get the low end dialed in so itt'l idle nice, then give it a modern 2.4g receiver, a modern LiFE Rx pack, and get it in the air!
Perchance, anyone know what this thing is? The guys in the Glow Nation FB think it's a Midwest Aerostar 40 trainer.
You done good. In most cases, the engine alone would cost you that much. That said, I have three recommendations for you:
1) Remove the engine and mount and refinish the nose of the plane. I saw what looked like bare wood and, if that is the case, it would soak up oil rather quickly, destroying the structure.
2) If you remove the engine, I'd tear it down and soak the case in warm used antifreeze. It will, when used with a nylon brush, remove all the grime from the outside of the case which will allow the engine to cool more efficiently. An old, small crock pot would work well in this situation.
3) I'd replace the prop and spinner. Both look fairly beat up and, since you don't know if the prop has ever had a ground strike, it would probably be a good idea to get new one of each, balance it and install them.
FWIW it had an ANCIENT Futaba receiver in it when I got it. 1/2a glow clip with D-cells in it for scale.
Those are adapter cables to allow modern servos to plug into this thing. It's got four reasonably modern servos and they all move freely. I'll know whether they're functional or not when I get an R2006GF in there and get it bound to my 6J. If there's any question regarding their health, I have a full set of brand new S3004s sitting on my desk. They'll be fine in a plane like this.
Regarding cleaning it, my plan was to get some brass wire wheels for my dremel, set it to its lowest setting, and run that between the fins. Shouldn't mar up the aluminum any. I'm a bit hesitant to pull the backplate on this thing at the moment. It doesn't use an o-ring for a seal here and if I tear the paper gasket it currently has itt'l never run right until a new gasket is fitted. Shouldn't be too hard to track a gasket down, but until I've got one on hand I'm not keen on popping the backplate off.
I didn't film them, but I did do inverted(With <1/4 tank in it) and nose-high WOT tests. It didn't care. The tank is still sealed up well, the clunk is still clunking as it should. Ran an entire tank through it today, more or less, and I only started it once.
Spinner appears to have wear from e-starter use. I noticed pretty quick that this thing has its own wants regarding startup. I tried to start it like I start my 46AX and it didn't even pop. It draws fuel up to the carb just fine, but if you stop priming it when the fuel hits the carb and start flipping to start you get nothing. However, if you damn near flood it, it fires off on the first flip. I'm guessing the previous owner never found the 'combination' and resorted to an e-starter instead. Need to pull the prop anyway to get sizing info on it; I have no idea what the pitch is but if I were to guess I'd say it's a 10-6 or 10-7. I do know the engine pulls strong on it, so it's getting the same size prop put back on either way.
My Feedback: (29)
It's fairly common for a plain bearing engine to require a bit more prime for starting then a BB engine. If it has sat for a while it will need the additional fuel to establish a film seal between the crankshaft and the bushing/crankcase. Once the seal is established it will draw fuel up into the combustion chamber more efficiently. Great score though, one thing I have not had around for a while is a small trainer, I miss having something to just take out and fly for the heck of it. Enjoy.
Indeed, maukaonyx is correct although it is the Midwest Aerostar 40. Built in two sizes forty and twenty all were kits that I am aware of . It is a fine trainer and my second choice only to the Sig Senior Kaydet Long ago I used one with fifty ounces of fuel for my personal best cross country along seventyfive miles of Route 66.
No modifications at all are required so do not get caught up in that game. FP's along with the later FX.s and the more recent AX,' s are absolutely at the top of my favorite glow engines and yes even over the Four strokes.
The carb on all sizes of the FP's is a bleeder type, An example of simplicity. Very easy to set midrange but is backward from the double needle types ( Leaning midrange is done by opening the screw, not closing). I would be pleased to explain a very simple method if interested?
John
John
Now onto the RC system This receiver is most definitely an early Futaba AM type not an FM, Which is Very wideband which makes it illegal to use as such. It cannot be convertible to any modern (legal) standards
The battery packs are: an early futaba 4.8v 500mah Nicd. get rid of it. The other pack is not for the RC system, Perhaps it was intended as some sort of fulltime/switched glow booster. That's rubbish. The FP's are the most reliable and least in need of any glow boost, Ever.
The Servo Plugs are the Futaba (G) which were last used in 1986, They are not compatible with anything due to uneven pin spacing. As one of the fellows stated the adapters (G plug to J plug) have been out there but at what price for what you end up with? There is a "Cheat" which involves cutting the lead and replacing with an old/new J plug being very careful to get the power polarity right. If done wrong this will let the smoke out of the Rx.
One last though I would heed Hydro's suggestion to trash that spinner it is so damaged (starter cone burned) as well as aged (lost to much moisture) that is just waiting to explode wheather when starting or as sometime happens in flight.
John
John
John
John
I'm impressed with how broad the needle settings are, too. I can go half a turn on the high speed before the thing reacts! Great plume of blue out the back(I fumigated my mailbox with this thing from across the street hahahaha), no missed cycles, and a needle that practically sets itself. Gotta love it. And the LSN...I gave it a half-turn-in from where I had set it when I cleaned the carb and that was dead nuts on. Thing idles down to 2750RPM like it's nothing and transitions flawlessly even after burbling over for a minute or two.
Always have loved OS power. My 18 CV-RX is an absolute brute, my 46AX is boss, and now this 40FP goes from 'siezed solid' to 'fine runner' with a bit of 3'n'1 oil chased by 1/2a fuel and 2hrs of wiggling.
And yeah, I definitely buy the 'plain bearing film seal' angle, because my Cox engines are the same exact way. They tend to not start at all unless they're literally puking out the exhaust slits.
It's astonishing how enormous that receiver is for only being 4 channels. Something that footprint from the last 3 or 4 years would have 20+ channels, two-way comms, built-in 6-axis gyrostabilization, rudimentary autopilot capabilities, telemetry feedback, the works.
As for my Aerostar 40...in all likelihood, itt'l get the same Rx I have in my NexSTAR, an R2006GS. I don't need anything fancy in here, just a dependable S-FHSS full-range receiver. The servos in the plane currently use standard J connectors, and if they don't work, I have four brand new S3004s sitting here waiting to go into something.
Yeah, puts a decent datestamp on the airplane. I found a manual for the 40FP; copyright 1987, and the receiver that was in it uses depreciated servo connectors that were obsoleted earlier than that. Plane was prolly built in the early 80s. Makes it older than I am!
John
John
I'd rather use less weight with more leverage to get the CG right, yanno? If 5oz of brass on the end of the crankshaft balances it as well as 16oz of nails under the back end of the fuel tank does, I'm saving 11oz of weight!
My Feedback: (29)
It was very common back in the day to have the CG too far forward. Many of us ( myself included ) had it beat into our heads that a forward CG was more stable. Not entirely true but not entirely false either. What the forward CG does is mandate some up trim. On the plus side that up trim would help self correct if you started to build too much speed in a shallow dive. On the negitive side it also ment that the pitch trim would only be correct at one given airspeed and while using excessive elevator throw to compensate you can cause a nasty tip stall. Moving the CG back compensates for the drifting pitch trim some. With some fiddling between CG and downthrust you can almost eliminate it completely. All depends on what your preferences would be. I would personally set the CG to 30% and elevator throw to around 15 degrees.
Someone on the Flite Test forums has one he built 25+ years ago, showed me a pic of the plans for the fuse. CG is supposed to be 3" back from the leading edge on it according to the plans for the kit. He's also the guy that had to make lead blocks to mount on the cheeks right behind the prop to balance it.
I reckon that's a fine starting point. If I find it needs a lot of up trip to fly level I'll prolly shift the weight around a bit. My preferences are to a plane that flies like it's on rails with no twitchy tendencies; I am a novice pilot after all. Much as I'd love to have a nimble warbird or aerobat, I probably wouldn't be able to control such a plane quite yet haha.
My Feedback: (29)
Contrary to popular belief, having the CG back a little from where the plans show does not lead to an airplane that is any more nimble or twitchy. It simply makes it where the pitch trim remains more constant. It will also lower the stall speed. At 3" behind the leading edge I would expect a wing cord of around 9.5".
Huh. Apparently this thing's needing ballast so much because the 40FP is far too light for the airframe, that it was designed for a dual ball bearing engine rather than a plain bearing engine. And now I'm tempted to try to find an FS-52 Surpass for it, recycle the 40FP into another airframe. Ahh, future plans~~
But yah, if the PO balanced it 3.5" back, I'm gonna go ahead and keep it there. I can find no evidence of crash damage on it anywhere so it clearly likes that CG. Might see where things fall with the modern receiver pack, receiver in there before I commit to a weighted spinner/prop nut...might also be fun to put FPV on the thing, which would also lessen the need for dead ballast weight. For now, though, I'm getting it in the air again. Fancy things come later.
Presumably the servos are from around the late 80's also. You may want to consider getting a voltage regulator in line with the LiFe pack, keeping it around 5 volts. Many of the older electronic items were not very tolerant of being fed much more than what a 4.8v Nicad could put out, hot off the charger. Likely they will be swapped out real soon, anyway - probably very "economy" models from back in the day, meaning no bearings except for the plastic case, pretty low power, prone to dirty pot issues, etc.
The Aerostar, while sold as a "beginner" plane, is a really good flyer - you'll have a lot of fun with it!
Servos themselves...Tower still has a listing for them and they have ratings for 6 volts. Won't burn out because of a Li-FE.
'Tis worth noting that this one was built with barely any dihedral. If it has any at all, it's only a degree or two. My FT Commuter 049 has about 5 degrees or so, enough to visibly see it, and my NexSTAR has so much you can fly it like a 3 channel by merely not touching the ailerons. Should be a good platform to learn basic aerobatics on!
My Feedback: (29)
Back in the 1980's I worked at Northern Californias largest hobby shop. We used to set up some of the off-road R/C cars with servo power coming straight from the motor battery pack. At the beginning of the run the S148 servos would be getting a tad over 8 volts. Never smoked one. They will be perfectly fine with 6.5 volts. I used to set up my Hirobo Shuttle helicopters with the same servos and 5 cell nicad packs, the additional voltage would spin the gyro faster for faster gyro response.
I still have a bunch of 148's in the "old servo" box. True, likely not much will happen to them, but...they were/are Futaba's lowest end servos. While I too ran 5 cell NiCad packs with them, note that 4 cell NiCads can produce up to 5.8v right off of charge. Five can go to 7.25. LiFe's can be 7.3. So while rated for "6v", they get pushed to up to 50% higher than the nominal 4.8v they were originally designed for. This is, of course, only for perhaps the first flight or so, and then the packs settle down to their rated voltage. I have seen premature death due to higher voltages back in the 5 cell days, but it was pretty rare. The biggest issue with those servos was that they used the hole in the case top as a bearing. The hole would elongate due to wear over time, and the servos would get worse and worse at holding neutral as the shafts rocked back and forth under load. I may still have a few that were retrofitted with aftermarket ball bearing case tops....but that didn't really improve them all that much. Best use would be for throttle only.
I will evaluate the servos and decide whether to replace them when I get a receiver and receiver battery put in it. I've got four S3004s sitting in my parts bin that are brand new, but I'm not going to disturb the linkages and risk cracking the 40 year old servo tray if I don't have to.
I still have 4 Aero Stars , a 60 size with an OS 90, 2- 40 size, one with a 52 and one with a 56 . And the one I fly now is a 20 size with an electric motor . The glow jobs just hang on the wall enjoying retirement . Red
