saito's and mufflers
been flying saito 120 and 180 for 3 years. never could keep a muffler on. ruined threads and lost mufflers. saito 180 is worse. FINALLY, looks like I may have it solved:
extra strength red locktite ( 550 degrees ) works. also have always had problems with exhaust deflectors. nothing stays on and the extra weight vibrates the muffler loose. did this: installed 1/2 inch ID stainless flex gas pipe. comes with fittings. remove them. do not, do not clamp the flex to the muffler. leave loose and secure flex to landing gear or under the plane somewhere with a stainless hose clamp screwed to bottom. the flex pipe is strong enough to stay in place over the muffler outlet and lets the muffler vibrate within the flex with no strain on the muffler.
Also drilled and tapped the muffler to the header pipe and used locktite there also.
RE: saito's and mufflers
On both my OS91fs and Saito 150, I use a short piece of aluminum tubing. Get a size that won't quite slide on so the threads will cut in slightly. Then put a slit about 1/2" long in the end of the tube. Use a muffler clamp to hold it tight. Sounds great and cheap to replace if it does fall off.
Tom
Tom
