Recess for Robart Hinge points?
IL
First time for me using Robart Hinge points. I have read the how to section on www.airfieldmodels.com but it doesn't address my issue. How do you recess for the hinges on a large surface such as the wing? Airfield suggests using a rounded file. 2nd, do you always recess the fixed component, i.e. the wing, the stab and the fin? Why not aileron, elevator and rudder?
Using Robart Super hinges 3/16" with ProBond glue in a H9 Taylorcraft ARF. Any suggestions or advice would be appreciated, pictures especially!
ST
ST
ON, CANADA
RE: Recess for Robart Hinge points?
Sean:
They should be recessed into the aileron, elevator, rudder. I use a Dremel with a carbide cutter and elongated in the vertical direction to allow for the up and down movement.
IL
IL
Thanks for the advice! Stick Jammer the moving surfaces are single beveled, the flying surfaces are 90 cut. Is it correct then Flypaper 2, that I only need to bevel the moving surface to clear the knuckle?
I tried a sample, but the sharpened brass tube wobbled too much to make a clean hole. Might have to go buy a 3/16" forstner bit.
Sean
Sean
ON, CANADA
Sean:
The idea of insetting is to get the leading edge of the bevel and the fixed surface as close together as possible without touching. The pin should be just in line with the bevel. You can take a 1/4 in. drill and turn it with your fingers to go in about 1/4 in. in the movable surface to inset the hinge. Put some vasaline on the hinge pin area to keep from getting glue in the hinge.
IL
