Windex Method
Windex Method
What exactly is the "windex method?" I am a little unsure on how it is done. Can it be used on both Monokote and Ultracote? Does the film need to be ironed afterwards? How permanent is it after it is done? Any help on how to do it or where to find it would be great.
BCP
BCP
My Feedback: (12)
IL
RE: Windex Method
Ahhhhhhh......... the Windex Method, yes I use it all the time. It works great for applying covering over covering and decals. I spraying the covering with Windex, smear it around a little then lay the other covering over it. I smooth out the bubbles with a sheet of balsa and soak up the extra Windex with a rag. Let it sit for 24 hrs then apply low heat to glue it down and voila done. I Like Ultracote because it sticks at a lower temp than Monokote and that way no bubbles will form. I use the Windex to apply decals the same way except for no heat, just let it air dry.
RE: Windex Method
Does it work with Ultracote too? I thought I read somewhere that it only works with Monokote. Is trim solvent necessary for the edges?
Moderator
My Feedback: (58)
RE: Windex Method
ORIGINAL: BearcatPilot
BCP
BCP
IN
RE: Windex Method
I used transparent econocote. (i.e. low temp & cheap) on this bird. All I did was hit the edges with a iron on low setting after it dried. I NEVER had ANY problems. It turned out AWESOME!!!
Derik
Derik
DC
RE: Windex Method
The "Windex" method can be used on a bunch of applications, including self-adhesive trim sheets and decals, and probably any application where the adhesive is not water-soluable.
Actually, all you're doing is using a film of water to keep the trim from sticking until you have it exactly in the right spot. Then, eventually, the water evaporates, and the adhesive takes over. There's nothing magic about Windex, it's just that a little detergent in the water breaks the surface tension. Just plain water would work, but it beads up on most surfaces.
Some people have posted that you don't need to use trim solvent or heat with Monokote. However, I have done tests, and in my tests, if you don't use heat or trim solvent, you can peel off the top layer without too much trouble.
If you're going to spend a lot of time doing a design in Monokote, I suggest you test a little before you commit to the no-heat no-trim-solvent method. Just iron a piece of Monokote onto scrap balsa, windex on a piece of trim, let dry overnight, and try to peel off.
DC
RE: Windex Method
ORIGINAL: barto
What is windex exactly
RE: Windex Method
Barto a very good question?
I had to look in my old regular file cabinet for a formula that works like windex. Here is what I found basically its distilled tap water with a small amount of cleaning ammonia and blue coloring added. About one soup spoons worth of ammonia to a 12 to 16 once spray bottle is all thats needed and use one drop of common dish washing detergent added to the mixeture. I don't think the blue dye coloring does anything more then help sell the product.
RE: Windex Method
Thats a nice looking plane Thunderhead. I asked this question because I intended on doing some sort of patriotic/flag scheme on one of my next models. Thanks for the replies everyone.
BCP
BCP
My Feedback: (26)
RE: Windex Method
Just wondering if there is any trick to getting the windex method to work on Ultrakote? It does work well with Mono but the one time I tried it with Ultra, it was a failure. I waited about 12 hours and when I went to check the pieces, the Ultra just lifted up. It seemed that the windex did not activate the adhesive on the Ultrakote. Anyone got any ideas what I did wrong? Thanks in advance.
My Feedback: (13)
RE: Windex Method
You need to use heat.
The windex allows the trim piece to lay flat, and provides tension to hold it in place so it won't slide off.
There may be something in windex that activates monokote adhesive; but with U-cote ya gotta use low heat once all the windex has evaporated (overnight).
Another option is MonoKote trim solvent, but you get ONE shot at that. Once that stuff hits the adhesive side, that piece is THERE and ain't moving; which is why I save it for last, going around the edges to form a seal, as it were. This eliminates the need for a second going-over with high heat to seal the piece down.
Again, this is the way I do it, with success, It certainly isn't the only way. YMMV...
OK
RE: Windex Method
cbreeze:
I have had good luck using Windex and Ultrakote. I used the blue Windex which contains ammonia. Not all Windex solutions contain ammonia. I believe that the presense of ammonia tends to "kick" the adhesive. After it all dried I hit the edges with an iron on low heat (220). No problems so far and one of my aircraft is in its second season of flying.
Works for me...
Dan
Works for me...
Dan
RE: Windex Method
Just for clarification on this method, I assume that the wing needs to be completely shrunk fit before appling the top layer? What if you have to go back and shrink the monokote more on the wing, what happens to the top layer?
And the other question I have is about the trim solvent. Do you peel up the edges of the top coat and put it on the adhesive side, or do you just apply it to the edge and it wicks into the seam? Also does the trim solvent hurt the finish if it is on an area that doesn't have another piece of monokote over it?
My Feedback: (26)
WI
RE: Windex Method
I assume that the wing needs to be completely shrunk fit before applying the top layer?
I've always done mine without solvent.
PA
RE: Windex Method
> The windex method works with monokote only <
I just tried this as a test on Ultracote and the trim piece fell off after I squeegeed it.
DC
RE: Windex Method
ORIGINAL: Dsegal
DC
RE: Windex Method
ORIGINAL: fstevenj
I'm not sure what you mean by "hurt the finish". Trim solvent won't do anything to the non-adhesive side of Monokote.
RE: Windex Method
Strange. In Australia Windex (Same name at least) is water and Methylated Spirits (Denatured alcohol). At least I think Methylated Spirits is what you call denatured alcohol.
Methylated Spirits is 95% Ethanol.
Would this be the same thing as your Windex ?
I make my own home made Windex out of this and it smells the same and works identically to Windex.
