Extension on needle valve
Reply
Old 11-20-2003, 01:27 AM
wagondriver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Extension on needle valve
I have a OS 46 and the needle valve does not extend outside the cowl. Does anyone have any ideas on what can be done to extend something on the needle valve so the engine can be tuned.
wagondriver is offline
Old 11-20-2003, 05:23 AM
Smoky
Smoky's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Extension on needle valve
On my OS .61 I used a piece of music wire poked into the center hole on the Needle valve,
and soldered it in. I then tightened the set screw to hold it there. The 1st one wasn't soldered and fell out. I then bent the protruding end like the end of a T pin. so It was easier to make fine adjustments with.
The worst thing about this set up is you have to unscrew and remove the needle valve before removing the cowl. I tried the same thing on a 4 stroke Saito .91, but it
Vibrated too much and wore an oblong hole in the cowling, before it too snapped off, I just use a long slender screwdriver in the hole now. I seldom have to adjust this needle anyway.
Smoky.
Smoky is offline
Old 11-20-2003, 10:36 AM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also use a small L-shaped hex key as a ready made extension. The kind that come with a package of wheel collars is good. Be sure to put thread locker on the set screw.
Dsegal is offline
Old 11-20-2003, 10:44 AM
MustangFan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Central Hobbies has a needle valve extention for $11.00.
Check it out ... seems well thought out.
MustangFan is offline
Old 11-20-2003, 04:46 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most Needle Valves have a hole with a set screw so that you can simply place a piece of scrap rod (like push rod) into the hole, and hold it with the set screw. Then, as others have said, bend the end into an "L" shape to give you something to turn.
MinnFlyer is offline
Old 11-20-2003, 08:22 PM
Azcat59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can dress down a 2-56 Allyn head sheet metal screw (DuBro) so it will fit in the hole in the needle valve, and tighten the set screw on it. Then use the 2-56 size ball driver through a small hole in your cowl to adjust the engine. Neat and clean solution, nothing outside the cowl.
Clair
Azcat59 is offline
Old 11-20-2003, 09:56 PM
bentgear
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use soft wire, accidents do happen.
Ed M.
bentgear is offline
Old 11-21-2003, 12:08 AM
Azcat59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I can post pictures of my TT 120, you can see the head of the sheet metal screw at the end of the needle valve, ready for a ball driver for adjustment.
Clair
ID:	76355   Click image for larger version
Azcat59 is offline
Old 11-21-2003, 12:21 AM
GrnBrt
GrnBrt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about the needle valve on ST engines??? They have a piece of wire in the center that you cannot get out, nor can you add an extension. It has bugged me for a long time, this design.
GrnBrt is offline
Old 11-21-2003, 10:54 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea Art, I think Enya used to do that too. I just came across one of those in my shop this morning.
Old 11-21-2003, 11:29 AM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Art,
Can't you grind a slot in the end with a Dremel and use a screw driver?
Dennis-
DBCherry is offline
Old 11-21-2003, 02:45 PM
Azcat59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Art, I know what you mean about the ST engines. Cut the wire off to about 1/4" in length, and then solder a piece of 3/32" brass tubing over the stub, and also with your wire extension in it. Or, solder the SM screw, as in my pictures, into the brass tube. Would be easier if they just followed the OS approach, wouldn't it!
Clair
Azcat59 is offline
Old 11-26-2003, 05:24 PM
michpittsman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DB-I grind a slot in the head for a screw driver, or , as an option, grind flats on opposite sides of the nob and cut a matching slot across the end of a dowel or brass tube tha engages it. Extending a wire through a hole in the cowl just makes the cowl hard to get off...JIM
michpittsman is offline
Old 02-05-2004, 06:11 PM
hercibird
hercibird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the same problem with my Fox .60. not having enough room outside the cowl. I took an old needle and cut the needle off leaving the grip. I made a collar out of aluminum tubing and JB welded the two needle grips together using the collar to keep it all together. Works great and looks stock!
hercibird is offline
Reply
Display Modes
