Painting with Chevron-smell/basement?
NY
With this cold weather snap in the northeast, How bad will the house smell if I brush on Chevron paint working in the basement? My shop in is the garage and even with a small electric powered oil heater, I don’t think I can get the garage warm enough. What do you guys do? [:@]
ON, CANADA
RE: Painting with Chevron-smell/basement?
Just don't do it. I painted with Chevron once and I would never do it again. The whole house smelled and my family almost killed me. I had to open all the windows a day later to air it out. I have since moved to the small Tamiya paints, they don't smell nearly as much. I find if my family can't tell that I am spraying in the basement then they are ok with me. I just use Lustercote Clear after about a week of drying. Or you can wait for a nice dry spell in a couple of days or so. I am in Toronto and the weather is forcasting a little above freezing on the weekend, you could dry then?
Good luck
Good luck
I've sprayed Chevron paint in a 45 degree shop. I didn't notice any problems. It still seemed to flash off fairly fast. I let it sit over night before I moved the plane, though.
WI
I paint on the back porch (enclosed) in our apartment. It gets fairly cold. If its 20 outside its about 48 back there. Anyway, I have a window fan that sucks the fumes out, and I allways use a resperator and goggles. I've never used Chevron paint, but I have sprayed dope back there as well as automotive paint and that stuff is nasty. Fortunately for my wife & cats, the porch is closed off from the rest of the apartment. The big PITA for me is the damn dust this city produces. Anyway, if you're in the basement though w/o any ventilation, I wouldn't do it. You'll get very high and stink up the whole house [:'(]
Joe
Joe
I plan to spray dope inside (unfinished basement) and expect it to stink.
I simply plan to enclose the area with light weight plastic sheeting and setup a fan to exhaust the fumes out a small basement window via a length of 8 inch diameter vent tubing. If everhting is sealed it should create a negative pressure environment - i.e. air will leak in, but no out. I expect that will keep the stink at bay.
The incoming air will be filtered by a cheap furnace filter, so it should help with dust control.
I also have a good respirator to use.
WI
Joe
OR
I paint in my basement, smells up the house for a while and my wife and kids complain but they have gotten used to it. It goes away in a day or so.
