heat coverings
FL
RE: heat coverings
The lighter coverings won't warp delicate structures as bad. Solarfilm, for example, doesn't have as much shrinking power. However, it is also "softer" in that it feels rubbery after applied so it probably distorts more in flight.
What plane are you having the problem with?
TX
RE: heat coverings
Hi twostrock,sounds as you are using to much heat.,I use a iron with built in thermostat control,also have separate thermostat to check iron heat.I lay ultra cote at 250 temp and mono at 275,at 300 both start stretching,use only just enough heat to do the job.
My Feedback: (8)
RE: heat coverings
Econokote or tower cote is pretty pliable and low-shrink, and I've herd of guys like faye stilley (?) pre shrinking the covering to an extent in your avrage oven. Don't know how he does it but he does, if it's a small electric, use nelsons lite-film. If you like the cloth look use world text, it's simply outstanding and easy to apply.
