Help me bend aluminum!
My Feedback: (28)
I need to slightly bend the header section of a Genesis Throttle Pipe muffler to clear the fuselage on my Giles 3D. It's hard to explain, but I just need to open up the radius between the header flange and the muffler section.
I'm assuming I will want to heat it up. How hot?
Thanks!
Thanks!
TX
RE: Help me bend aluminum!
Not sure but I think that your header is heat treated and you wont hve much luck bending it. You might be better off using some aluminum sheet the thickness you need and fabricate a spacer by using the exhaust flang as a template, then attach as you normally would with longer screws.
That will be tough to bend, I think you would be better off making a spacer. You could have this piece machined from aluminum bar stock.
OH
Heating aluminum to bend it will ruin it.
Generally, you can't succesfully unbend a bent tube, you'll end up with a second bend or worse, you'll kink it and ruin it. You will be better off to make a second intentional bend near the first, instead of trying to "unbend" it. Fill the pipe with dry sand, and use a wheel, pipe, or other suitable object to bend around. Make sure you "pull" the pipe around the bend, and not just force it over the object. You may also want to practice with a piece of scrap aluminum tube, even if it's not the same dia.
Hope this helps.
Jetts
Hope this helps.
Jetts
Try it first with a block of wood. If you do use something like this I would advise cutting a gasket for the spacer (both sides) and using heat resistant rubber washers on your screws if you can find them.
My Feedback: (28)
Thanks for all the ideas. I decided to abort the bend and just put on a 1/2" extension and a Mac's one-piece (which has a slight angle to it). It clears the bottom of the 3D Giles when I have the engine canted a bit.
I'll save the throttle pipe for my Flying Machine.
Thanks!
Thanks!
