Reload this Page >
Futaba T6XA problems
Old 02-05-2004, 07:24 PM
barkin_bob
barkin_bob's Avatar
Default Futaba T6XA problems
I purchased a T6XA in DEC. from Tower Hobbies and finally got a chance to use the radio last weekend Feb,1 Anyway here's the problem...... In the radio manual it shows a diagram for the receiver and servo hookups NUMBER 1 place is aileron , num. 2 elevator. Num 3 throttle. num. 4 rudder. PROBLEM IS the radio see's NUM.2 as the throttle where it should be num.3 This means that when I tried to adjust the D/R for the elevator it only moves the throttle position. I can't swap the servo wires because this makes the throttle stick control the elevator. It seems to me that something is bass ackwards IS IT ME , or is there a fix( PROGRAMING ?) or is it defective.
Thanks for any help. .
Old 02-05-2004, 07:37 PM
Stick Jammer
Default RE: Futaba T6XA problems
Sounds like the transmitter is in Mode 1 instead of Mode 2. Look in the manual under "Changing transmitter mode".
Old 02-05-2004, 08:49 PM
barkin_bob
barkin_bob's Avatar
Yep that did the trick. THANKS MUCH (IT WAS me)
Old 02-06-2004, 12:15 AM
DBCherry
Nice to hear someone admit it.
Seriously, there's a thread going on in this forum right now about people not saying thanks, or letting anyone know how things turned out. So thank you Bob.
Dennis-
Old 02-06-2004, 07:17 PM
Stick Jammer
You're welcome, glad to help. Just in case you didn't already know, your throttle trim question got moved here for some reason. I posted an answer.
http://www.rcuniverse.com/forum/More...1503660/tm.htm
