TRIM OR MOUNT ADJUSTMENT REQUIRED
KS
I have a GP super decathalon and in order for level hands off flying I end up with some noticeable up elevator at most all throttle settings. If everything was perfect wouldn't a plane with all control surfaces level with airfoils and stabilizers fly straight and level. The plane seems to fly good once trimmed. The wing has an incedence of 0 when the horizontal stab is level. I was wondering if I could shim the bottom of my motor mount (adding a little up thrust to help pull the nose of the plane up) to help with the trim situation. Ground handling is not real good either. When the tail comes up I have to give up elevator to keep the prop out of the ground. I think it all has to be related.
I am not sure if I was clear on my problem but for level flight my elevator is pitched up noticably a lot more than my trainer was when trimmed for level flight.
Banned
RE: TRIM OR MOUNT ADJUSTMENT REQUIRED
visit www.nsrca.org see thier aircraft trim table.
Remember... if it is not a symetrical airfoiled 0-0-0 design, then the table will be off a little in the dive tests. EXPECT a flat bottom airfoil semi-scale Cub to pull out of the dive on its own fiarly quickly as speed builds. That Decathalon... should be close to the chart.
ON, CANADA
Nose heavy plane will do this also. Try moving the CG back a bit to see if it straightens out. Another way to tell if it's a CG problem is wether it takes a lot of down elevator when flying inverted. Should take very little.
