UFO CA
Old 02-24-2004, 06:00 PM
RNick
RNick's Avatar
Default UFO CA
Is UFO CA as strong as regular ca? I have allerges and have to wear a painters mask to use ca. I would like to use ufo. But am not sure.
Randy
Old 02-24-2004, 06:35 PM
joebob
My Feedback: (14)
joebob's Avatar
Default RE: UFO CA
I used UFO for quite a few years and didn't have any problems with it. You will notice that it takes longer to cure than the regular stuff, and some say it doesn't dry as hard. The thick stuff is slightly more flexible than the regular. That may or may not be a bad thing, I guess, depending on the application. That said, it does keep the allergies away!
Old 02-25-2004, 07:57 PM
jettstarblue
jettstarblue's Avatar
Default RE: UFO CA
Works O.K., but why use CA at all? The UFO takes a long time to "set" and there are definately other less expensive glues that can be substituted.
Jetts
