most powerful rc electric motor
I need a motor that is less than 4" in diameter, extremely powerful (the most important property), and hopefully not to heavy either? any advice? and also how many lithium batteries would i need to run this plane for around 20 minutes?
FL
RE: most powerful rc electric motor
Probably more than that. My buddy just spent $175 on Li-Poly's for a small electric motor but his plane has unlimited vertical for at least 15 minutes. He says he can fly it twice having full power when he wants it or three times if he does fewer vertical maneuvers. And the plane is lighter than when he had NiCads that only gave him 8 minutes of good power and 12 minute flights.
I don't know jack about electrics, but I'd think the motor alone would cost over $300 when he says "most powerful available."
TX
I think this is the one they advertised at having as much power as a .90 four stroke....look at the bottom of the page, it will fly a 12 pound plane... http://www.hobby-lobby.com/brushless_axi.htm
WI
Astro flight makes some motors that will meet your needs. A cobalt 40 with a gearbox can move around a 18+ lb plane on 20-24 cells. If the cells were, say 10000mAh and you propped it to draw ~25 to 30 amps (say a 16x14) in flight you could go 20+ mins. Astro flight makes a 60 and a 90 motor that can take 32-36 and 36-40 cells repectively (NiCD cell counts, convert accordingly for LiPoly). The same size cells (but more of them) on a cobalt 90 propped to 25-30 amps could move the same plane faster than a 40 could or same speed, but larger. Being brushed motors makes them more affordable.
