Ready to paint Cowl for Sig Extra 300XS??
My Feedback: (22)
TX
I am recovering My extra. Is an Unpainted cowl for the Sig Extra 300 available??? Or can I sand off the paint of a new one, and just prime it for new color?
Thanks in advance
Thanks in advance
My Feedback: (7)
MI
Refinishing
Hi Coulter
If your just doing a color change like I did just wet sand the cowl with some 320 grit sandpaper but you do not want to srtip all the paint off the cowl the original paint is a great base for your color and at this point all your pin holes should be covered and you won't even have to use any primer.
Good Luck
Tom
Good Luck
Tom
Citation X a good filler for small pinholes is 3M Flowable Finishing putty it is a two part system just like body filler, but it sounds very easily and as long as you throw a little bit of primer over it to cover up the sanding scratches it will work perfect for what you want to do with it.
