epoxy question for all the epoxy experts
OH
well i messed up a bit, got the 30 and 5 min formulas mixed up. ended up using 5 minute resin (z-poxy) with 30 minute hardener (generic brand) on a rather critical joint. is it going to cure allright? any halp wpuld be appreciated.
D
D
MN
RE: epoxy question for all the epoxy experts
I would try to pull the parts apart, clean and reglue. If the parts have cured somewhat and you are unable to seperate, heat gently with your heat gun until the epoxy becomes soft. At this point you should be able to seperate the parts. While the epoxy is soft, carefully remove the excess glue with a xacto blade.
Mix up the correct batch, and reglue.
