Gasoline & Cline regulator
OH
RE: Gasoline & Cline regulator
Antique
The gas carbs already have the Cline built in. It looks like Bill Cline took the regulator section off a Walbro carb and closed the back side off and sells it to us glow fuel guys.
DEG
DEG
The Cline is specifically built for glow... so I'm not sure if it's gas-resitant...
The Ironbay regulator however is absolutely gas-resistant... but not methanol resistant... its membrane should be changed every year when used with methanol (which is what it is sold for )
So get the Ironbay regulator... it's cheaper to boot...
