Non Pneumatic Landing gears.
Know of any magazine or book articles on how to make retracting gear using fine pitch screws and electric motors? I have a model design in which there is not room for any of the air powered devices, and have been thinking of building a electro/mechanical type as the commercially available gears will not fit properly. Need some examples of how problems were solved.
Wm.
Wm.
Minn-Flyer
I used to also have access to a 1970 vintage CNC machine. I know Autocad and had a conversion program to turn into G-Code, etc. That option is gone now.
What I have is a local friend who does lost wax castings. We are going to go as far as possible in cast aluminum, replicating a few different styles of gears.
Wm.
Wm.
My Feedback: (-1)
CA
I have some Wing Mfg electric gears that would be a good example of non-pneumatic/non-mechanical gears. And I'm relatively close to you if you want to take a look (they're not mounted but NIB)
Problem I found with them is that the plastic piece that the strut goes into is weak (made of metal, I think they're work fine) and broke when I tightened the setscrew.
They use an electric motor to turn gear reduction that eventually turns a jackscrew which causes the "trunnion" (not sure thats the right term) to move in and out.
Kraft made electric ones too, but I haven't seen them.
