battery location
OH
battery location
well i know some people mount the batteries in the back of the fuselage, near the tail to achieve ballance without the use of additional weight. well when it comes time to replace the batteries, wich it will,... eventually, do they just cut the covering to get to it? is that the trade off?
anybody know any other tricks for a nose heavy plane?
thanks
D
thanks
D
RE: battery location
What kind of plane and what type of engine?
If the plane is still going to need tail weight, build a hatch for the battery.
Move all servos back as far as possible. Use a mini servo on throttle, if the servo is in the front. If you can put it behind the cg, use a full size servo. Reciever back as far as possible. Switch back as far as possible. Use a plastic spinner or a prop nut instead of an aluminium spinner. Lite wheels. Lighter muffler.Heavier tail wheel or lighter nose wheel. Anything useful rather than adding lead.
One note of caution on battery placement. You should not place the battery behind the receiver unless well secured. In a crash, the battery is a heavy missile wiping out everything in its path.
It doesn't take much lead in the tail to correct a nose heavy plane. I would opt for the lead.
BO
BO
hi
I have done this often with no problems...when building or even after completion if I find it necessary I build a box in bottom of fuselage at the rear and access it with a removable hatch. this has worked great with me. if removal becomes necessary or desirable you can drop the connection back down to the equipment switch through the formers or some have used paper tubes like used in wings to the aileron servos. remember to leave a small opening in the front of battery box to run the wire through.
happy flying
joe
happy flying
joe
My Feedback: (41)
Build a battery hatch in the back if you have too. Mine will never come loose. It's got 2 zip ties on it holding it down. It's more secure than any of my batteries. That story about it becoming a projectile? That can happen anywhere you put it if it's not secured well.
