Iron On covering ??
RE: Iron On covering ??
I've never used Towercote, but I'm guessing that your guess is right.
21st century film was the first one I tried outside of MonoKote many years ago. It is MUCH easier to work with, and shrinks much better, but after a year or so, the plastic seperates from the color. So I stopped using that too.
Once I tried Ultracote, I never looked back!
You would think so, but I will state here and now for the record that I am in no way affilliated with Ultracote (Or any other RC products for that matter). It's just that when I really believe in a product, I like to let people know about it.
(In case you haven't noticed, I like CA Hinges too )
My Feedback: (18)
I am about to start my first covering job and I already have bought the monokote. You guys make me worry how it is all going to turn out. Next time I guess I will try to go with Ultracote.
LA
again its like -=-which is better a FORD or CHEVY or DODGE. i like this, you like that. only by trial and error do you make up your mind. me --I like Monocoat cause never tried Ultracoat. I use Coverite on most of my giants. its strong and accepts paint real good. dick
The both have thier uses. I like Monokote because it does stick to itself so well. MinnFlyer likes Ultracote because you can get it off more easily later. It is a matter of preference. Both are excellent products. Lustercote, the paint that matches Monokote seems to be a better color match than the paint that is supposed to match Ultracote, althought Lustecote can be a pain to apply.
Try everything and use what works for you.
