Magnets in R/C aircraft?
RE: Magnets in R/C aircraft?
The glider guys use magnets to close spoilers. I am not aware of any particular problem that magnets will cause as long as they are not too close to the Rx. I suppose it is possible they might have some affect on the signal and, thus the antenna should be avoided as well.
I think the biggest problem is tha the magnets might not hold the hatch on at speed. In my opinon, there are many better ways to hold the hatch down.
i use them all the time to hold down hatches and cowls etc.you can get really strong ones,they do not affect the radio at all.
My Feedback: (90)
Magnets will hold hatches very well if you use "rare earth" magnets and put them in correctly. It's a common practice on lots of large scale aircraft. Especially large warbirds.
here's a link to more info omn magnets:
http://www.wondermagnets.com/cgi-bin...ts%3BNeodymium
As TLH101 says, they work great and have absolutely no effect on the radio. Rare earth magnets much smaller than a dime will hold a hatch on so tight you have to use a screwdriver to pry them off. Use them on many of my big (1/4 scale ) planes and on small gliders to hold the hatch on.
NY
Yep, I use them all the time to hold hatches and hinged canopys on. Just be sure to use rare earth magnets. They hold incredibly tight and I have never had one let loose in flight.
