Servo torque??
Old 05-07-2004, 01:08 PM
WindStalker
Default Servo torque??
I haven't come across any information yet on the proper size servos for any particular plane. I have this innate tendency to do things HEAVY DUTY, but I also don't want to break the bank either. Can anyone tell me if there is a general rule of thumb for servo torque requirements for say a 40,60, 1/4 scale size plane like a 300S?
Old 05-07-2004, 03:17 PM
danny03
danny03's Avatar
Default RE: Servo torque??
Really hard to say since a lot of your selection depends on the size of flight controls, airspeed, do a search in scratch built for an excel spreadsheet called servcalc. If you can not find it, give me your email and I will send you a copy...
Old 05-07-2004, 07:18 PM
Campy
Campy's Avatar
The manufacturer of the plane NORMALLY states how many oz torque servos are required. Since they make the plane, they should know what works best in it.
As a GENERAL RULE OF THUMB, standard servos (42 - 46 oz) are fine for general sport flying with a 40 - 60 size plane. Large control surfaces and/or high speeds and/or heavy duty aerobatics (3d type) will USUALLY require higher torque and/or metal gear servos. When you go to 1/4 scale the servo requirements USUALLY go up again.
There are exceptions to everything though. An example, I have a 1/4 scale PacificAero Gee Bee Y with an OS 160FX in it. The manufacturer calls for standard servos on the ailerons and elevator and a minimum of a 75 oz torque on the rudder. This is what I have put in the plane and it flys great - no problems at all.
