RC-56 Canopy Glue and Elmers Glue
Reply
Old 05-11-2004, 08:15 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RC-56 Canopy Glue and Elmers Glue
I just opened my first bottle of RC-56 glue. I have used other means before to attach canopies and windows. I wanted to try RC-56.
I have a bottle of Elmers white glue on my workbench as well. The RC-56 looks exactly like Elmers. It smells exactly like Elmers. It spreads exactly like Elmers. It dries exactly like Elmers.
Gee, I wonder if it IS Elmers?
FWIW...
Kmot is offline
Old 05-11-2004, 09:25 PM
bojangle
bojangle's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC-56 Canopy Glue and Elmers Glue
I've never tried Elmers on canopies. You might test on a sample to see if it penetrates and holds, and dries clear. If I remember, Elmers dries sorta cloudy.
BO
bojangle is offline
Old 05-11-2004, 09:35 PM
Tall Paul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RC-56 sets up somewhat flexible, and holds better on covering film than the alphatic resins.
Roughening the gluing surface helps maintain the grip.
Tall Paul is offline
Old 05-11-2004, 10:48 PM
Ryans Rebel
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tall Paul is correct. I understand it is formulated to stick to plastics much better than other glues. It also dries flexible (this is good because of the vibration) and clear. Elmars does not dry clear, it is not flexible, and it surely doesn't stick to plastic.
Put a little elmars on a piece of scrap Monokote and let it dry. It will flake off.
Ryan
Ryans Rebel is offline
Old 05-12-2004, 12:24 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well good, I hope it is different. What I did was I spread a couple drops of each on a piece of scrap balsa. Possibly the RC-56 was slightly thinner in viscosity but not much. Anyway, I can test it after 24 hours cure which is what the RC-56 says it needs. I don't know about the clarity of Elmers. But I did use it to seal my antenna inside a tube so there was a glob of it at the end of the tube. I will check to see if it looks cloudy.
Kmot is offline
Old 05-13-2004, 01:55 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My apologies to the makers of RC-56. [sm=redface.gif]
I did another side by side comparison test, using a piece of clear Lexan. RC-56 is definitely thinner viscosity than Elmers. It dries relatively clear; Elmers dries opaque. RC-56 sticks to smooth plastic; Elmers comes off easily and completely.
There is a marked difference between the two.
Kmot is offline
Old 05-16-2004, 12:38 AM
Shogun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've use RC-56 for years and even during some pretty violent crashes NONE of my canopies have come off. Be sure to shake it well before using it and make sure that both surfaces are clean and oil free. I have never roughened up the gluing surfaces since the tackiness and holding power of the glue is adequate. In many ways it bonds more like silicone than regular glue, great stuff.
Shogun is offline
Old 05-20-2004, 06:23 PM
bryfly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is there anyother alternatives to rc-56 that holds just as well and easier to attain--would hot glue work???Just a question?
bryfly is offline
Old 05-20-2004, 07:02 PM
SilverEagle2
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hot glue will more than likely warp the canopy plastic due to heat. A really thin bead of silicone caulking also works if used sparingly.
Jason
SilverEagle2 is offline
Old 05-21-2004, 11:29 AM
Steve Collins
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used RC56 a lot and it is a good glue for canopies for the reasons already mentioned. I have, however, found a glue that is much better. In its hobby guise it is marketed as PFM by Innovative Model Products. I have found that what PFM really is is an industrial adhesive known as E6000. Naturally, a tube of E6000 is much cheaper than the "repackaged" PFM. E6000 is already clear right out of the tube. Like R/C56 and silicone, when cured it remains flexible but is much harder/tougher. It's bond is also far stronger than either of the other 2. Likewise, it can be cleaned up with water before it cures.
I have found that large craft oriented stores carry E6000. In the St. Louis area there is a craft store chain called "Michaels" that has it as a regularly stocked item. I have also found E6000 at Home Depot. If you can't find it locally, you can get it here:
http://www.gluguru.com/Sealants.htm#e6100
Steve Collins is offline
Old 02-12-2015, 08:28 AM
rfmillte
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RE:RC-56 Canopy Glue replacement
Micheals Has E6000 but the thread to http://www.gluguru.com above does not carry it. I may try a tube of E6000 it is larger than RC-56 and cheaper. I also have a Michaels store fairly close to me.
rfmillte is offline
Old 02-12-2015, 02:37 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just about any of the 'craft' glues used to adhere items to T-Shirt materials will work as the glue is flexible.
tailskid is offline
Old 03-13-2015, 07:45 AM
K-Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wal-Mart carries E6000 in the hobby section.
K-Bob is offline
Old 03-13-2015, 08:04 AM
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You must put a lot of canopies on. My bottle of RC 56 has lasted years.
raptureboy is offline
Old 03-03-2018, 11:26 PM
sticktickler
sticktickler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RC 56 canopy glue replacement.
Walmart has a product called Gem-Tac found in the craft department. Gem-Tac is very similar to RC56 Itís non-toxic white when wet dries clear and flexible water clean up. Comes in nearly the same kind a bottle as far as Iím concerned the stuff is virtually identical!
sticktickler is offline
Contact Us Archive Advertising Cookie Policy
