Finding the CG?
Finding the CG?
Loopman
Start about 1/2" behing the leading edge of the bottom wing. If it wants to land fast, start moving it back until you can slow the plane down to a comfortable landing speed and still maintain solid control without being sensitive.
You will probably end up about 1" to 1 1/2" back from the lower wing leading edge, but better to start on the safe side.
Silversurfer
Silversurfer
Questionable C G Location
Am working on a FF Quaker Flash from the 1930's. The "Balance Point" is noted as being about at the rear trailing edge. The engine, fuel tank, coil, landing gear, etc really hang out in front. The plans indicate to balance the A/C by moving the Burgess battery to the rear as much as necessary.
The W/S is 66", chord of 9" (flat bottom), area is at 543 S.I., over all length of 42 inches and weight of 2/14. Does not have a lifting stab, but it is big.
I think the Balance Point a bit too much to the rear. Should it be moved forward, (considering lighter weight late model equipment), or left as is?
Wm.
Wm.
Try this web link
I haven't used it myself but it seems easy enough to just plug in the measurements and it will work out the CG for you.
Finding the Centre of Gravity
Steven
Steven
