flap servo's
ON, CANADA
flap servo's
hi everyone im building a great planes rv-4 was woundering if i can use hs81mg servos for the flaps since i probably wont use them much and the torque is ok any comments?
My Feedback: (24)
MS
RE: flap servo's
You probably could, but consider the Hobico CS35 or Hitec HS225 (I believe they are one and the same) at .95 oz. with more holding power. I've use both in scale ships and the Hobbico's worked out best at a minute weight increase. You could use them on all the surfaces and an HS81 on throttle if you're serious about weight on that particular plane.
quint
quint
