glichting
glichting
I am having a problem with my servos glitching. I have a fuji 32b installed in my edge 540 and it is giving off a lot of vibration. I did a range check without the engine running and the aerial down and i got full range but with the engine running I only got about 15 feet. this only happens when the engine is runnig at idle once you open the throttle it stops glitching. I learned this the hard way when I was coming In to land I put it back to idle and it started glitching so I quickly opened it and just got it before it was smashed into the ground.
RE: glichting
First make sure you have no metal (Wires or pushrods) that go from the engine atea to the receiver area.
Next, I would wrap some extra foam around the receiver. It could be that at a certain RPM, the receiver is getting just the right vibes to make it go screwy
