Glow plugs????
ND
RE: Glow plugs????
the plug coil is made of platinum, same stuff as in your car's catalytic converter. Once it is heated up, it will continue heating in the presence of methanol and oxygen.
MD
RE: Glow plugs????
All good answers. The glow plug is very similar to the heat plug in a diesel automotive engine.
There are a lot of variables such as nitro content of fuel, heat range of the plug, ambient air temperature and barometric pressure which affect the exact properties of the ignition.
ND
RE: Glow plugs????
RE: Glow plugs????
Kramer is correct, they are the same stuff as a car catalytic converter. Many years ago, glow plugs were a quarter. Then we got catalytic converters and the price started going up.
Platinum works as a catalyst better in elevated temperatures so we use a coil of wire and a bettery to get the process started. The rabid environmentalists are trying to get our catalytic converters hooked up like a glow plug to car battery power so the converted works when the engine first starts. It would probably be hooked up to an interlock so if the circuit didn't work, the car wouldn't start.
And they are also trying to get catalytic converters put on RC engines. Small engines are, according to them, a good part of global warming.
WI
RE: Glow plugs????
I thought nitromethane, at least, was a fairly clean burning fuel. Am I wrong in that assumption?
I forgot, never to *** u me Lets strap a big ol propane tank on a plane,,, or better yet how about natural gas,, I have more than enough to go around "pfffffft" [sm=lol.gif]
