Control throws on an older Kit
I have a Top Flite Freshman trainer. This kit was produced before they included the control throws in the manual. What would be a good starting point to set them at(low and high rates as well)? Thanks for your help.
RE: Control throws on an older Kit
First thing I would be sure of is the planes CG per the plan. Then the throws would depend on the radio you are using. If you have the capability go with a touch larger throws than the Sierra and mix in some neg expo. so the controls arn't so touchy.
Darren
Darren
