Loose monocote
Old 06-25-2004, 07:30 AM
Gary496
Default Loose monocote
After crasing my trainer several times I have had to recover the front. Now I can't keep the covering on the the darn thing. I cleaned with acetone ,but to no avail. I am using Monocote and using high heat with my iron. It will seem to be stuck, but after a couple of flights it starts to peel. I know I could CA it down, but I rather not do that as if it (the plane) makes it though the summer I want to strip her down and recover. CA will be hard to strip. Suggestions please.
Old 06-25-2004, 07:41 AM
waagbuck
waagbuck's Avatar
Default RE: Loose monocote
If you're going to recover anyway at the end of the summer, just try clear packing tape over the seams.
Old 06-25-2004, 09:15 AM
quint-rcu
My Feedback: (24)
quint-rcu's Avatar
You could have fuel soaking the wood under the covering, and in that case Monokote doesn't stick well. Try cleaning the fuel out with one of the comercial products for that. Sometimes I've found Ultracote sticks better to slightly fuel soaked wood.
quint
Old 06-25-2004, 10:14 AM
MinnFlyer
MinnFlyer's Avatar
After cleaning it as best you can, a coat of Balsarite will help the covering stick.
Old 06-25-2004, 10:22 AM
Campy
Campy's Avatar
If the wood has fuel in it, K2R works as well as regular talcum powder. Put it on the area(s), let it sit for a couple of hours and brush off. You will probably have to repeat this several times to get the fuel out of the wood. The apply a coat of balsarite to the wood.
Old 06-27-2004, 09:28 AM
Gary496
Thanks for the info, all. I guess I'll have to try on the next plane as I totalled the trainer yesterday. I did get some fly time on my Tiger 60 , so the day was not a complete loss.
