scales used to weigh a plane??
My Feedback: (22)
FL
strange as it seems I want to weigh a plane I built because it was done with a foam wing and it is definitely heavier than the original built up version..I want to weigh the overall plane to ensure it complies withe kit recommendations. I am curious as to what everyone does and the scale used.is there an inexpensive piece of equipment to accomplish this ..please help..
ON, CANADA
RE: scales used to weigh a plane??
How accurate do you need to be? Weigh yourself on your bathroom scale. hold your plane and weigh again. Difference is your "approximate" answer.
My Feedback: (12)
SC
Good tip on the fish scale. Here's one:
http://www.dickssportinggoods.com/pr...oductId=975329
My Feedback: (22)
FL
eureka! I was at wally world last night(walmart) and looked at food scales just incase they had any and I found several! I bought one for under 9 bucks!!! I rushed home and weighed my plane under construction and though the foam wing was unbelivably heavier overall I am well within the specifed weight given by the kit designer..so if your looking for a inexpensive set go to walmart in the grocery section where they sell food related supplies.this works in grams and pounds up to seven pounds..
