Larger Building Surfaces
FL
I'm just wanting to get some suggestions as to what types of building surfaces you all use to build larger planes. I'm getting ready to begin construction on a Don Smith B-17 (yes...I know) and the fuse is 96"...therefore the plans are even larger. I'm running into two problems. The largest sheet of plywood I can find is 96"...a few inches too short and the second problem is...sticking a t-pin in a sheet of plywood or wood door isn't that easy.
Any thoughts and/or advice?
Patrick
Patrick
FL
RE: Larger Building Surfaces
I'm sure a dumb question here but where do you buy marine plywood? I would assume a boating store? But aren't most boats these days built using fiberglass? So I'd assume it would be pretty difficult to locate in addition to being pricy...
Pat
Pat
QC, CANADA
Build an extra long table, using two peices of MDF, and a joiner under teh seam.. (like, 2 sheets of 5'x4' MDF for a 10' x 4' table..) then a sheet of 10' gyp-rock / sheetrock on top of that. You can get 12' sheets of wqall board, and I beleive 10' as well. You can puchj pins into gyp-rock / wallboard / sheetrock.
