what do I use for decal fuel proofing
I just have a couple of questions;
1 whats a brushable fuel proof for decals?
2 Is acrylic paint fuel proof?
3 Is minwax acrylic clear coat fuel proof?
I was hoping you might know of somthing to use that can be bought in a hardware store
RE: what do I use for decal fuel proofing
MANY of the paints for plastic models are fuel proof, I believe Tamiyna (spelling?) is.
I know ACRYLIC LACQUER is fuel proof, I "think" acrylic enamel is also.
If you are not sure about a paint, do a test panel first. Just use a piece of scrap wood.
I am not sure about the MinWax acrylic clear. I do know the regular MinWax polyurethane (oil base) does yellow from age/exposure. I KNOW that 2 coats Minwax PolyCrylic (the water base) is non yellowing and fuel proof to 10% (maybe more). I did a test panel using 2 thin coats of the polycrylic as a clear coat. I let the polycrylic dry for 8 hours, then poured 10% nitro fuel on it and let it sit for 24 hours. At the end of 24 hours the clear coat was "a little" soft. This was noticeable as a slight "dragging" on the cloth when cleaned, but that was all. I feel that I am not going to leave raw fuel and/or fuel residue on my planes for 24 hours before cleaning them, so no problem.
When I make my own water slide decals, I fuel proof them with a thin coat of either LusterKote clear or Ultracote clear. I use the MinWax PolyCrylic for fuel proofing the whole plane (I paint using latex).
Hope this helps.
Hope this helps.
Thanks for your help,Im glad to hear Tamya is fuel proof ,Thats what I used on my cowl,
Im surprised that it is because its water based acryllic.But I love that Tamya paint its the best I ever used.100% hummidy and it still dried in 3 minutes..lol My local shop just set up a stand of Tamya paints and im trying to get a good selection for my self set up.
I will try your test and see if it stands up to fuel.One paint I dont like is Master Modeler
There flat paint doesnt dry to a consistant flat,shiny and blotchey looking.
Boy if they only had Tamya paint when I was young I would have made some master
peices..lol I also like the way RC stuff has come to be afordable,as a kid that stuff was way out of bounds,you had to just dream of it.I guess thats why my hytec radio says on a label"Touch your dream"....lol Thanks for your help,I love this universe ..lol
If you are going to be doing much painting, you may want to investigate using regular latex paint. It can be color matched to almost any color for about $8 - $10 a quart. If you brush, use a foam brush with latex and it works great. The catch, it takes MOST latex paints 7 - 10 days to cure before they can be clear coated. I have heard that SOME brands can take as long as 30 days. I do not have the link available, but there is an excellent article on painting with latex paint. A search should get you the link if you are interested.
