Difference w white monokote
My Feedback: (18)
Last night I was covering a wing with monokote. Primarily white on the bottom and red and yellow on top. Is it just me or does the white monokote not shrink down as much as the colors? So far I have used white, blue, cub yellow, red, and black and it seems like I always spend more time getting the wrinkles out of the white. Maybe I am just crazy.
AZ
RE: Difference w white monokote
I've found that different colors of Monokote have different shrink rates but, not drastically different. The application temperature and the shrink temperature are the same no matter the color. Oracover has one application temp and another higher temp for shrink.
DC
This was discussed a while back in a thread, but I forget the title. The consensus was that your experience is common. I believe (with no scientific evidence) that white is different because they have to make it as opaque as possible. Baxter (GP Support) was on the thread, but wouldn't say anything other than if you think it's defective, send it back.
My Feedback: (18)
I dont think the role is defective and it works fine. It just seemed to me that it shrinks less or that it requires a little more heat to shrink an equal amount. I can imagine that different colors would behave diferently. I was just curious if others have thought this as well.
Community Moderators
My Feedback: (42)
I personally haven't seen as much handling difference between the standard colors. Metalics and pearls OTOH do not, for me, go around corners or shrink anywhere near as well as the standard solids. I can't comment on transparents as it's been many years since I used it and just don't remember.
John
John
You are not crazy, unless we both are crazy, which could be the case. The white does take a little more heat to shrink. I have found that different colors do work at different temps. To me white will also turn transparent when pulled hard around corners.
Dru.
Dru.
Now you know why MANY modelers have changed over to Ultracote (Oracover). Ultracot (oracover) now have matching paints too. My experience with the Ultracote paints have shown that they spray better than LusterKote and cover better also. The match is as good and in some cases better than LusterKote.
Just my $0.02 worth.
