What shall I put into the Chris Foss Wots Wot Bi plane?
Engine wise that is I definitely want a 4 stroke but can I have some input as to what make, size to get? OS 70 Surpass? Irvine? ASP? Saito!?
Decisions, decisions.
RE: What shall I put into the Chris Foss Wots Wot Bi plane?
I have a Saito 72 and absolutely love the engine. Easy to start and VERY reliable. I have never had a dead stick with this engine. The power of the engine is somewhere between a 53 and 61 2 stroke using 10% nitro.
One thing I would do is to use a drop of locktite on the set screw for the needle valve extension. If you do ever need to get one it is 2.5 mm in diameter.
