crystal swapping Hitec Rx to Futaba Rx
NJ
Does anybody know if you can take a crystal from a Hitec Rx and put it in a Futaba Rx. It is the same pin size and spacing.
Has anyone successfully done this?
Thanks for any info.
1 Post
RE: crystal swapping Hitec Rx to Futaba Rx
Unfortunately, the Futaba dealer in Sweden is telling fibs. He is trying to sell more xtals &/or radios. They are interchangeable without loss of performance (as long as you have the correct high/low band).
hi
I don't know what the difference is but it is my understaning that hitec uses a special crystal for their receivers. I do not think it will work in a futaba...they use a hi and lo receiver structure, think channel 35 is the change point. don't think I would risk it.
good luck and happy flying
pt19 flyer
pt19 flyer
MI
I have used GWS crystals interchangeably in both Hitec 555, Hitec Supreme and Futaba 127 receivers with out any problems. These receivers are of the dual conversion type and the crystals are for dual conversion receivers.
Gordie
Gordie
ORIGINAL: aeroflyer
Put a hitech x tal in a futaba rec. the rec turned green
