hinge gap sealing
hinge gap sealing
I used 3M tape called Blenderm. It is a clear surgical tape and it seems to work very well for sealing hinge gaps. Read about it on www.gsal.org
I usually seal both the top and the bottom of the hinge surface. It is really only necessary to seal the bottom though.
hinge gap sealing
jabowil,
I purchased the blenderm from www.3m.com they have an on-line store. I think it cost like $22.00 for 12 rolls of tape. This is pretty much a lifetime supply. If you don't want to buy a whole box e-mail ([email protected]) me and I'll sell you a couple rolls. The rolls are 5 yards so 1-2 roll should do an average size plane. Go to gsal.org and look on the discussion board, in one of the archives there are some posts about hinge sealing. I'm not sure if there is a search engine on the site.
FL
hinge gap sealing
I use the clear 2" sealing tape I get from the U.S. Post Office. Clean the covering with alcohol, cut the tape to length, fold it in half lengthwise and put it on the hinge line. Sticks great - never had any come loose and it's practically invisible.
