Smallest, lightest NiMh's
I'm looking for the smallest and lightest 4.8V 4-cell pack available anywhere for my Jeti Rex 4+ RX. Currently I'm using a 4-cell pack of 2/3AAA which weigh 30g. I need to cut this to about half the weight if possible.
I did track down four cells of 1/3 AAA, but they don't have solder tabs, so no way to solder them together?
Help!
Help!
NJ
RE: Smallest, lightest NiMh's
what are you flying that you want to cut out so much weight, and if you want to that badly, buy some LIPO batteries, and get a longer flight too.
I'm flying a 29" Modela Itoh with C02 motor. It a super little model and weighs just 70g without radio gear. I need 2-Ch r/c because the last one I built disappeared over the horizon on its maiden free-flight!
I want to use my Jeti Rex 4 Rx and 2 micro servos. These come in at just 20g. My current NiMh pack (2/3AAA) weighs 30g all by itself, so I need to cut the weight of batteries by half.
I considered LiPos but the voltage is all wrong for the Rx (4.8-6.0V). I did procured four 1/3AAA cells weighing just 12g, but they don't have solder tabs. I believe its not OK to try and solder them directly?
WA
www.cheapbatterypacks.com has 1/3 AAA. Don't know about the soldering tabs. They will build the pack for you though. Use thier custom pack builder. I have had good luck with them, I have probably made about 15 orders with them.
I just noticed you are in the UK. I am not sure what their shipping policy is.
