spinner instead of prop nut for performance
MA
i have a Saito .82 on a UCD .46 and i was told that if a spinner is used instead of a prop nut or nut with a backup nut that you will get more rpm's using the spinner...does anyone know if this is true?
My Feedback: (12)
SC
RE: spinner instead of prop nut for performance
Maybe, but if you use a spinner and only one nut you need to make sure the nut is really tight. I've had them come loose several times. I use a spinner on my Saito 45 and include tightening the prop nut on my list of things to do before every flying session. I wish the shaft had room for the spinner backplate, washer, and two nuts. I did just come across a product that was called a washer nut. Seems it works as the prop washer and a nut. Would let me have a lock nut. Need to look into it more.
My Feedback: (10)
PA
well a spinner is supposedly better because the way the props are not really aerodynamic in the center near the hub. if you have a spinner, the prop sticking out of the spinner is more aerodynamic and not causing as much drag. so maybe you might be able to pick up a few rpm
My Feedback: (16)
GA
In the air, Maybe. ON the ground, I don't think so!
ORIGINAL: tukkus
