*Recovering A Plane*
RE: *Recovering A Plane*
Use an iron and a heat gun to get it off the really stuck parts. If a little adhesive stays behind, it is really no big deal. If you have trouble getting the new covering to stick, either use balsarite or a solution of elmers glue thinned with water.
Good luck, and welcome back!
Deadeye is right. You grin and bear it. If some small pieces of the colour backing come off. You usually can sand them down with fine sand paper. Otherwise Deadeye has it right. good luck.
Mark Shuman
Mark Shuman
