3 Questions about engine + covering + kit
Hi,
1. I have never build a kit and wanted to ask, if I can cover the plane by using an household iron, I mean one of those you iron your clothes with ?
2. Then, how do I decide if an engine is too big for an airplane? The case is I have only a .25 engine available, but wanted to build the Lanier Stinger 10, they say .10 to .15 is the rec engine size. Will it fly with a .25 OS engine?
3. I'm german, so I don't really understand what the Stinger 10 kit includes, what do I have to buy else except for the radio and engine? And it isn't really a kit, its rather a ARF, I mean if it says foam wings, they are already "built" right? Sry for those stupid questions, but I have no clue of english names for R/C parts.
It says "Foam Wing with Partial Balsa Sheeting and Cap Stripping Required' What is required???
"Vacuum Formed Canopy" What is the canopy??
Sry for these dumb questions
thx and bye bye
thx and bye bye
RE: 3 Questions about engine + covering + kit
Ok let me try and answer this one for you.
#1. Yes you can use a regular iron as that's what a lot of us did when Monokote first came out, just set it to cotton.
#2. A .10 would be the low end for an engine and this model and a .15 would be the high end recommended by the manufacturer. a .25 would over power it but it could be done, just would need to use the throtle more and it probably would be nose heavy and you would have to add weight to the tail to get the correct CG.
#3. I have never seen this kit in person but let's say it's a built up plane, not an ARF and i am basing that on question number 4. the wings are cut out of foam and from the sounds of it you will be putting sheeting on the foam at the leading edge and trailing edge, then using thin strips of balsa you would simulate ribs, make it look like it's a built up wing.
a canopy is the hood that goes over the cockpit. It is clear just like on a real plane.
the questions aren't dumb and one has to start somewhere, hope I have been able to help you out.
My Feedback: (12)
SC
ORIGINAL: polish smiley
I've found that most manufacturers have web sites, and most of these provide details about their kits. For example, here is the URL for the Lanier Stinger 10: http://www.lanierrc.com/lrcprivate/r...es/sting10.htm
If you go to that link you will find a VERY detailed list of the parts included as well as the additional parts you need. They even tell give you an exact part suggestion, such as "LXB904 Dave Brown Lite Wheels 1 1/2" (2)" rather than "Wheels 1 1/2 in (2)". Very nice.
You should be able to get the same information when you finally decide on a kit that is appropriate for your .25 engine.
thx guys, then I'll have to find a hobbyshop near me and look at the kits and ask them for advice which kit I should buy for my engine. I hoped it'll work with a .25.. What exactly happens if the plane is overpowered? wouldn't the .25 engine use its power to lift up the 3 oz it weights more than a .15 engine?
Hi!
A too big engine is going to make havoc with a small model because it will make it too nose heavy, have too much wing loading, perhaps too agile, this combination is not suitable for a newcomer.
I recommend that you get in touch with a R/C flying club in neighborhood and try to get someone to help you with flying.
A good trainer is the ARF trainer from Kyosho "Calmato" which requires a .40 engine like the OS LA .40 with is a good reliable engine for this airplane.
Regards!
Jan K
Sweden
Regards!
Jan K
Sweden
My Feedback: (12)
SC
ORIGINAL: jaka
