wing cores
NE
RE: wing cores
Andy,
Depends on what kind of wing you are doing. If it is going to be vaccum bagged then you probably want the pink or blue foam that is about 4# cubic foot and looks like little bubbles of foam. If you are going to just put in spars and cover it with paper or balsa then the white 1#cubic foot stuff that looks like little beads of foam all stuck together is better because it is lighter. Send me an email at [email protected] and I will spend more time offline composing a reply. Also if you use AOL IMs you might look for me as robear1053 or icerinkdad.
Bob Furr
Bob Furr
