How to flat thin balsa?
RE: How to flat thin balsa?
As above, dampen the wood first (a little water works fine), but you might also want to try to bend it slightly in the opposite direction when weighting it down. That will do a better job of taking out warps or twists.
Pf course, if not done propoerly, the piece could look like wet spaghetti when it's dry. [:@]
Dennis-
Dennis-
