Econokote vs. Monokote
I read that Econokote is a low-heat covering designed for foam wings or balsa planked foam wings. My question is: can it also be used as a normal covering; I inadvertently got one roll of black econokote and one roll of black monokote. Can I mix them? Thanks. Jack
As Lennyk says dump it. Use Monocoat or ultra coat, but because I live in the hot area I have started to using coverite fab because I dont like having to shrink the cover all the time the keep it tight to keep the wrinkles out
